DAQ vis don't appear in LabVIEW
I have a simple DAQ card and installed NI-DAQ onto the computer. Afterwards I installed LV 6.1. Why do the DAQ vis not appear in the function tool box?
Thanks for helping.
Jerome.
(2,762 Views)
You did things in the wrong order. You need to install NI-DAQ after you install LabVIEW. If the NI-DAq installer doesn't find LabVIEW, it won't install the functions.
(2,761 Views)
Thanks, Dennis, for the advice. Do I need to reinstall both again or is there any other way fix the problem?
Jerome.
(2,756 Views)
I think all you need to do is re-run NI-DAQ installation with the modify option.
(2,754 Views)
Thank you very much. That did the trick.
(2,747 Views)
