DAQ with CAEN VME TDC
I'm using 7.1.  I'm not sure what you're asking about replacing VXIout.vi.  The VI's I got from Caen have calls to subroutines that call a version of VXIout.vi that is also from Caen in a directory called V1718Lib.  The VIs I got were sent to me by support people in Italy.  The 2 sets of demo files they sent me were V792_LabViewDemo.zip and V812_LabViewDemo.zip
Message 11 of 14
(1,237 Views)
      I got some problem with accesing some the TDC V1290N register using labview 8.2.
1)When I look at the 0X1002 status register, using CAENVMEDEMO program, it gave me  Hex 3837
when I use my brief labview TDC to look at it, it gave me hex 820,860,960. this indicate that the data_ready is set to 0. This is true when I try to read the  data output. I have no problem with data output using caenvmedemo.
My labview 8.2 code for QDC works fine.
2)Second I was thinking of using the labview example code from the CAEN wepage. It was was the V775 TDC.
I was thinking of modifying the code for V1290N.
When I test run it I got a problem "VXIin.vi" was stopped at node "" at a call to "Out Port Old 6.x.vi"
it seen that I'm using CAENVMElib instead of VXI. (the controller module is V2718 using optical link cable)
Message 12 of 14
(1,220 Views)
I don't think I can help you with the specifics, but I'd strongly suggest you talk to Caen.  They were very helpful for me.  I had email contact with Maura and Stefano in the Italy and they sent me more examples and answered any questions I had.  It was mainly Maura who worked with Labview.
Message 13 of 14
(1,206 Views)
Hi do you have maura contact email?
if you could email this to wizzee@yahoo.com1111111
thanks
Message 14 of 14
(1,192 Views)
