DAQ with trigger is very slow with PCIe-6351
Dear forum users,
I want to do DAQ with TTL trigger with the PCIe-6351 card and BNC-2110 front. The idea is to use a 5 kHz TTL trigger source (connected to the APFI0), and collect single-channel 100 data points (using analog input) with 1 MHz sampling rate. So each collection window is about 0.1 ms, and the DAQ speed should be mainly determined by 5 kHz, which is 0.2 ms per cycle. However, when I ran the vi (see attachments), the time for the while loop is always > 250 ms. Is there something wrong in my vi that makes trigger so slow? Any suggestions would be much appreciated, thanks!
(2,028 Views)
The LabView version is 19.0f2
(2,027 Views)
Hi hoaminw,
Why do you use an analog input trigger with a "digital" TTL signal? Why not use a digital input trigger?
Starting the task also takes some time…
(1,993 Views)
Accepted by topic author haominw
I'm pretty sure you're going to find that you need to do this indirectly.  Although you *could* configure the finite AI task to be retriggerable, you'd also need to retrieve all your samples from the task buffer in the ~100 microsec after one finite acquisition completes and before the next triggering signal.  I wouldn't count on that working out reliably.
A different approach is to configure a counter task to generate a retriggerable finite pulse train that acts as the sample clock for the AI task.  The counter can be set to generate 100 pulses at 1 MHz in reaction to each trigger and the AI task can use counter output as its sample clock.  (The AI task should be started *before* starting the counter task.)
You could then further declare the AI task to be continuous so you'll be free to retrieve the data at a more leisurely pace.  Maybe retrieve 50k samples at a time so your Read loop can iterate 10 times a second?  Then you can rearrange them into 500 separate subsets of 100 each if needed.
-Kevin P
(1,970 Views)
Hi GerdW,
I actually used an analog input trigger, not strictly TTL. I know starting the task takes some time, but that shouldn't take that long (~250 ms). I also tried self-trigger the DAQ and it works out properly with loop time of only 1~2 ms. So I think this delay is mainly caused by the trigger function.
Thank you for the help!
(1,821 Views)
Hello Kevin,
Thanks for your suggestions! I tried something similar and finally it works.
(1,818 Views)
