DAQ
I use DAQmx to write a number 1 signal then write to level 0. I use Osiloscope to measure this signal and see it delay 1ms. How do I fix it? Thanks everyone. My DAQ is NI ELVIS II.
Message 1 of 13
(4,977 Views)
Hi hung,
How do I fix it?
Short answer: Write a better VI.
Long answer: What kind of answer do you expect with such a question? You don't provide informations about your problem, and you forgot to attach your VI.
It would be much easier to understand that sentence when you would have attached your VI: what is a "number 1 signal" and where is "level 0"?
Message 2 of 13
(4,955 Views)
 My problem is to write a digital signal to NI ELVIS II device. First I will write HIGH and then write LOW. I found my code to run for ~ 1E-6 ms, but when I use the oscilloscope to measure the digital signal, I write that I see the HIGH level exists for 1ms and then return to LOW. I want to reduce this time right away because ~ 1ms is too big. Thanks you.
Message 3 of 13
(4,949 Views)
Hi hung,
From the specs it seems the Elvis only supports static DIO, so you will not get much faster using them.
But you could use counters/timers to generate short pulses. you could also generate a pulse using an AO channel…
Message 4 of 13
(4,945 Views)
Hi GerdW,
I understand your idea, but I don't know how to do it. If using the Digital Output of NI ELVIS II device like I did before, the delay time is quite large, I need time from high to low is immediately (approximate ns). If you know how to do it, you can create a VI to help me. Thank you very much.
Message 5 of 13
(4,939 Views)
Hi hung,
the AO channels allow for upto 2.8MS/s (for single channel), so the minimum time between two samples can be 357ns.
The counter/timer use 20MHz clock, so the minimum time between two samples of a pulse can be 50ns.
In the example finder you will find example VIs, which show how to output waveforms on AO channels or how to output pulses using a counter/timer!
"immediately" is impossible - you need to obey physics.
(Maybe you should first write down your requirements before choosing some DAQ hardware?)
Message 6 of 13
(4,929 Views)
hi GerdW!
Thaks you.
Message 7 of 13
(4,922 Views)
Hi GerdW,
I used Analog Output instead of Digital Output. But the results are still not satisfactory, I cannot explain this. whether there is another option or I have to use another DAQ.
Message 8 of 13
(4,913 Views)
Hi hung,
the slow part in your VI are those "1 chan 1 sample" DAQmxWrite functions: doing DAQmx with just one sample is slow.
Please try to adapt those DAQmx examples with triggers…
Message 9 of 13
(4,908 Views)
Because you are still using software timing!
I'm not familiar with the Elvis.  But if it behaves like other NI DAQ devices, you need to set up a sample clock,  create an analog waveform, and output it using 1 channel N samples.
Message 10 of 13
(4,906 Views)
