DAQ
The code's attached - I'm trying to read up to 8 voltages at the same time. The code I've written is crap - is there a better way to do it?
Thank you for any help you might be able to give me.
(3,240 Views)
Use the DAQ assistant express vi. You can set it up to return all 8 channels at once
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(3,235 Views)
You do not need the case structure full of duplicated code. Pull one of your for loops out. Then use code similar to what I have attached to feed the appropriate physical channels input to the for loop. Note that I replaced your enum for Selection with a standard numeric so I could perform mathematical operations on it. (You can do math on enums, but since the item order in you enum is reversed, the math gets messy).
Lynn
(3,224 Views)
And here's yet another way. I changed the enum. I think it's less confusing this way.
(3,219 Views)
