I reinstalled the LabVIEW 8.2 and DAQmx8.3 on my laptop today. After the installation, the DAQ6024E card doesn't work anymore. I tried to open the test pannel in MAX, and it shows an error: "Diese Operation kann nur bei physikalischen analogen Eingangskanaelen angewendet werden. Laut Konfiguration hat diese Hardware keine analogen Eingangsverbindungen." (The operation can only be applied on a physical analog channels, according to the configuration the hardware has no analog input connections. )
If I start the test, an error will be shown: "Fehler -200099 ist bei Test-Panel aufgetreten, Moegliche Ursachen: Kein physikalischer Kanal angegeben." (Error -200099 occurred, possible reason: no physical channel available.)
The selftest in MAX is ok.
Before it works with DAQmx8.1(I am not sure about the version number).
It seems that the card is not correctly recognized. Is there any possibilitiy to config the card?
Or Anybody has an idea on it?
Thanks a lot!
