DAQ970A does not show in NI MAX, but it is shown in Keysight Connection Expert
I have the following issue:
Turns out i do not see the usb instrument device DAQ970A from Keysight in my NI MAX. I can interact with this instrument through Keysight Connection Expert.
The Instrument appears in "USB Test and Measurement Devices".
I already tried in device manager selecting the IVI Drivers.
I can seem to find the solution for this problem.
I need to use this instrument with usb interface in labview.
Message 1 of 10
(4,683 Views)
You will need labview device drivers for interacting with the device which is available from below link.
https://www.keysight.com/in/en/lib/software-detail/driver/daq970-labview-driver-for-the-keysight-dat...
CLD Using LabVIEW since 2013
Message 2 of 10
(4,657 Views)
I installed the labview keysight drivers for communicating and device still does not show up in NI MAX 
It is still shown in Keysight connection expert as following:
And in my device manager it also is displayed as USB Test and Measurement Device (IVI)
and in my labview program i can access to device's function palette:
but i cannot access the instrument through the constant, it just does not show up.
Message 3 of 10
(4,627 Views)
Accepted by topic author JorgeOrtiz97
From Measurement and Automation explorer go to Tools and select Reset Configuration Data.
Then restart the system and then check in Measurement and Automation explorer
Message 4 of 10
(4,619 Views)
I was able to solve it, it turns out i just needed to turn off the daq's file access off (which i had it on) in the user settings. Thanks, this issue is solved.
Message 5 of 10
(4,599 Views)
Hello
I am sadly facing the same issue. Can you please explain how you did turn off the daq's file access? I can not find where to do it.
Kind reguards
Message 6 of 10
(3,516 Views)
To deactivate the DAQ's file access,
You need to go to User Settings
- I/O
- USB Settings
And there you will find the option File Access, just need that option Off is selected.
Message 7 of 10
(3,301 Views)
Disabling File Access did not solve my problem.
I loaded the DAQ970 driver from MAX (Measurement and Automation eXplorer) discovery screen.  The DAQ970A showed up in the MAX device tree and I renamed it to DAQ.  When I loaded and run the example ohm measurement, I received a read error.  Then after trying to resolve this error by following the Keysight LabVIEW driver installation instructions, which had me load prerequisites loading the IVI common code (KtDAQ970 IVI-C Driver for the Keysight Data Acquisition System version 1.0.0.0 or greater) which caused me to lose the DAQ970 as a VISA device in MAX device tree and a USB Device in Windows Device Manager.  It now presents as an "USB test measurement device (IVI)" in windows Device Manager and still “No VISA device found” in MAX device tree.  However, I could still access the DAQ using it’s USB address where I can successfully query the device ID  from MAX Tools>NI VISA>VISA Interactive control: double click my USB instrument (DAQ970A) Input/Output tab: Basic IO, write "*IDN?/n" then read "Device Info NO ERROR".   Then trying to duplicate the ID query in a LV program using VISA write/read commands, the VISA write the “Query ID SCPI command” is successful but the VISA read fails??   I have not found any helpful information on the internet.
I have since disabled the IVI drivers and removed all IVI files, MAX could find my DAQ970A and Windows Device Manager insists on presenting it as an IVI device.
Message 8 of 10
(3,073 Views)
thanks for the comment!
I was having same issue; Keysight DAQ970A just suddenly (after working fine for days) deciding to not enumerate correctly. In device manager it presented as if it had no driver.
Turned file system access off, reboot the device and now it enumerates again.. weird
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
Message 9 of 10
(1,337 Views)
None of the previous solutions (by themselves) solved my problem.
1. New/udpate drivers
2. Turned off file access
Still showed up as DAQ970A in Device Manager with "!" and did NOT show up in NI-MAX.
Went to DAQ and turned OFF LAN completely, and it immediately showed up in NI-MAX.
It was acting as if with LAN turned ON, it would NOT allow the device to register as USB device in NI-MAX.
/shrug, hope that helps someone.
Message 10 of 10
(623 Views)
