DAQCard-6062E with AI Read only returns scans in multiples of 100
Regardless of how many scans I request to read with AI Read, the number of scans read is always returned as a multiple of 100. This happens with a DAQCard-6062E on a Dell Latitude laptop with Labview 6i.
Is there a way to return fewer scans (say 10) without using Set DAQ Device Information.vi to set interrupt generation for every scan? I am scanning at 1000 samples/sec and don't want to generate 1000 interrupts/sec.
(2,521 Views)
Can you post your code? This shouldn't be happening, but I'm not sure how you are implementing this. It seems, from your description, that you may be asking for the wrong thing.
Mike
(2,521 Views)
