DAQCard Self-calibration
I have an application that uses two DAQCard-16XE-50 cards. One is for
measuring 0-5 volts from an SC-2345 and one is for reading RTD outputs from
an SC-2042. I want to do a self calibration of the cards prior to starting
data acquistion. If I use the "Calibrate E-series" vi, will it self
calibrate both cards? The "Calibrate E-series" vi does not have a terminal
for a device number, but instead a task ID, but I can't find a good
explanation for what this is.
Message 1 of 1
(2,771 Views)
