DAQMX Task startup & property changing slow
Hi!
I'm trying to make a very fast eventchanging Digital I/O-reader, which should be able to change events on for same I/O under ~20ms.
However, Stopping the task, setting the property node (fe. Change Detection & register event for Change detection) and starting the task again takes ridicilous amounts of time (100ms+).
Is there any way around this?
The Tasks are allready reserved before starting the program for faster usage.
Any ideas?
Message Edited by Nallez on 08-01-2007 06:43 AM
(2,816 Views)
Accepted by topic author Nallez
First key question: is it really necessary to stop and re-start the task?  Or is there another way to accomplish your purpose?  For example, if you stop and re-configure to be sensitive to transitions on different DIO lines before re-starting, you might be able to take the following approach:
- Configure hardware once to be sensitive to any transitions you're ever interested in.
- Configure a software filter that can evaluate the changes acquired and decide if they are the "right" ones.
- Instead of stopping, re-configuring, and re-starting the hardware task you would just re-define the software filter parameters for a new definition of "right".
-Kevin P.
(2,805 Views)
Yeah. I have to try to just start the task once after configuration and then work with the events.
Thanks for the idea. (Tho I'm pretty sure I've allready tried that one :P)
Message Edited by Nallez on 08-01-2007 07:59 AM
(2,803 Views)
