DAQMx Timing Source not working with USB6216
The attached code snippet works fine with a PCI-6229 card to generate the Timing Source for controlling a Timed Loop. But throws up an Error saying that the Cntr_0 resource does not support the value demanded.  If so how to create a Timing Source using the USB-6216 card ?
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(2,867 Views)
You should probably include an image of your error cluster when you get the error. You should also consider mentioning all the hardware you are using and also what OS and Labview software you are using.
That said, I feel like USB latency will making using a timed loop in labview difficult. I might be wrong though.
(2,820 Views)
