DAQPAD-MIO-16XE-50 not installing correctly on LV 7.1 & Windows 2000
What is the correct LV 7.1 DAQ driver version combination for supporting DAQPAD-MIO-16XE-50 on LV 7.1?
I currently have LV 7.1 installed with NI-DAQ 6.9.3 and was able to install the driver for the DAQPAD-MIO-16XE-50. I then found that the DAQ vi’s were missing from my application. I installed Traditional NI-DAQ 7.2 to get those vi’s back in which it did.
Now I find that the driver for DAQPAD-MIO-16XE-50 is now missing again??
Best Regards,
MV
(2,621 Views)
Hi Matt!
Your DAQPAD is compatible with NI DAQ 6.9.3 (http://zone.ni.com/devzone/cda/tut/p/id/8177), so thats the version you need to install for sure.
LV 7.1 is compatible with this version of the driver so you shouldnt have any issues, i would recommend to uninstall the version 7.2 of Traditional NI DAQ and make sure you install the support for LV 7.1 when you install the version 6.9.3. If you still cant see the VIs on your application i would suggest to make a clean install on another PC.
Hope this helps!
Have a great day!
(2,611 Views)
