DAQPad 1200 problems on Windows 2000
I used DAQPad 1200 on Windows NT and everything was OK. On Windows 2000 and Windows Xp doesn't work. I installed last version of NIDAQ (6.9.3) and MAX doesn't recognize the board. Is there any solution?
A also try to use "Add/Remove hardware Wizard"but in the list which appeared there is no "Data Acquitision Hardware".
(2,699 Views)
try this solution:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/b5d63edc141548b586256adf005553a2?OpenDocument
(2,699 Views)
