DAQmx Base only supports multiple channels?
Does DAQmx Base in PDA module only support multiple Analog input channels?  DAQmx had 1Chan 1Samp but this is not the case for DAQmx Base.
(2,796 Views)
hellolv,
You need to use DAQmx Base with the PDA module.  DAQmx Base 2.0 does not have a single channel single sample Analog input option, however if  you use the multichannel single sample option  you can still specify a single physical channel when you create your AI voltage channel.
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(2,781 Views)
