DAQmx Channel Identification
Hi there,
I have a problem in using DAQmx channel property node ---> Channel
Type. many times this property node is giving error code -200088. Once
this error happend, labview needs to restart. but the probability of
working of this property node is 25%. I 'm clueless. I'm using this
property to identify the global channel types whether it is Analog
Input/ Analog output/ DI/O.
Any one suggest the reason behind this error.
Thanks in advance
Vijayasiva
(2,727 Views)
Vijayasiva,
What is it that you have wired to the "task" input of the property node? The error you are getting indicates that this task is not valid. Is it a task you define in MAX? Is it a task you create in LabVIEW? Could you possibly be clearing this task before the property node executes? It may help to post your code.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(2,713 Views)
