DAQmx Channels on a Remote System
MAX lets you view DAQmx channels on remote targets. However, I cannot find calls within the DAQmx API to be able to do this.
All I want is a list of available DAQmx channels on a remote system without having to deploy code to the remote system.
I have spotted two previous attempts at this question but I thought I'd try my luck:
https://forums.ni.com/t5/LabVIEW/DAQmx-remote-system-channel-list/td-p/2389710?profile.language=en
https://forums.ni.com/t5/Multifunction-DAQ/Edit-Create-Channels-and-Scales-on-Remote-System/td-p/335...
Many Thanks!
Nick
(2,982 Views)
Under Help Find Examples Hardware Input and Output >>> System Configuration you will find...
C:\Program Files\National Instruments\LabVIEW 2017\examples\nisyscfg\Show All Hardware.vi
Something in that area is where I would start poking around.
Ben
(2,933 Views)
