DAQmx Counter Gate Signal
Is there a way to drive the counter gate directly?
I would like to use the gate to pause and unpause the counter.  Would I need to drive the gate from another counter or is there a way to drive the gate on/off directly "on-demand"?
(1,597 Views)
I am using DAQmx Start Trigger VI to start a counter (Ctr0) using a rising edge of a pulse from a different counter (Ctr1).
I would now like to stop/pause Ctr0.
Preferably, using another rising edge of a pulse from Ctr1.
Is there a way to do this?
(1,610 Views)
The dreaded answer is, "it depends."
What DAQ device are you using?   What kind of task is programmed for Ctr0?   Can you describe your app & system in more detail so we can understand the "big picture" of what you're trying to accomplish and why?
-Kevin P
(1,531 Views)
