DAQmx Create Channel VI, issue when build
 When I try build exe project file
 I have  this error when build. see attached file.
 If I enabled the debug mode, the build is OK, but VI can not run since it said the vi is not executable, but I know it is exeable when I run it individual.
 see 2nd attached file.
 Thanks for help
(2,762 Views)
It is very hard to debug a picture .
Zip and attach your project for the benefit of everyone else who wants to help you.
But first, open First Look U Point Calibration2.vi and change the absolute path on the block diagram to a relative path.  Then open the build specification and add the dynamically called vi to the always included list.
(2,747 Views)
