DAQmx Create Channel "AI Force Bridge (Table)" does not work
I'm trying to implement a force measurement with Wheatstone bridges. Unfortunately the DAQmx Create Channel "AI Force Bridge (Table)" does not work. If I change to the "two-point linear" method the measurement is working. Are there any known issues? Also in the example vi (can be found here: https://decibel.ni.com/content/docs/DOC-12259) it does not work.
(3,070 Views)
Hi manuelwaser,
What symptoms are you seeing?
Brad
Brad Keryan
NI R&D
(3,058 Views)
all measured values are zero
(3,052 Views)
What do your table data and input signal (when using two point linear) look like? Table scales do not extrapolate beyond the table endpoints. Here's how the documentation for DAQmx Create Channel explains it:
When you use this scaling type, NI-DAQmx performs linear scaling between each pair of electrical and physical values. The input limits specified with minimum value and maximum value must fall within the smallest and largest physical values. For any data outside those endpoints, NI-DAQmx coerces that data to the endpoints.
If your table is something like:
Electrical | Physical
0 mV       | 0 lb
2 mV       | 50 lb
and the input signal is negative, the table scale will return 0 lb.
Brad
Brad Keryan
NI R&D
(3,039 Views)
