DAQmx Create Task.vi
I'm trying to start up LabView on a new computer that is replacing the old computer in an existing test rack, the system was working before the old computer crashed.  Now with the new computer I'm having to reload a lot of the software and applications.  It's asking me to find DAQmx Create task.vi but it does not exist on either the old or the new hard drive.
Where do I find the DAQmx Create task.vi ?
(6,202 Views)
It's in an llb so that is probably why you can't find it on the old pc if all you did was a windows search. It's part of the DAQmx driver and you need to install the DAQmx driver after you install LabVIEW.
(6,200 Views)
Thank you Dennis.
The drivers can be found at <www.ni.com/support> » Drivers and Updates » search within results. Please see the following link for DAQmx-LabVIEW compatibility: <http://digital.ni.com/public.nsf/allkb/97D574BB1D1EEC918625708100596848?OpenDocument>
Dan Richards
Dan Richards
Certified LabVIEW Developer
(6,155 Views)
Thanks guys.  I got it working by installing the old harddrive in the new computer, and then had access to the software/drivers that I needed.
(6,153 Views)
