DAQmx Error 88709
I'm running TestStand in conjunction with LabVIEW on a PXI/SCXI system.  I experience DAQmx Error 88709 only when running my TestStand sequence file the first time after all equipment has been powered down.  For all subsequent executions of the TestStand sequence file, I don't experience the error (everything runs fine).  I can reboot the controller and I don't get the error.  I only get the error after a complete power-down (all PXI and SCXI equipment).
In my attachment, the VI that causes the error is Output_Drive.vi.  In this VI, I'm acquiring data from two PXI-5114 Digitizers.  When the error occurs, data from the first digitizer is displayed on the front panel graph, but before the data from the second digitizer is displayed, the error occurs.  Data from the second digitizer is coming from a PXI-6711 Analog Out card.
In my attachment, Error Report.bmp shows the error report that I get.
Any ideas will be greatly appreciated.
(4,068 Views)
Do you get this error if you just run the VI in LabVIEW and not in TestStand?
Best Regards,
Adam G
(4,037 Views)
