DAQmx Read Property Node pulldown - Logging missing
Question 1: I have run the original VI well on one computer. When I copy this to another, the error shows in the DAQmx Read Property Node.Both computers are installed with Labview2009 version9.0. I have used 'Logging' Property in my original VI. However, on the new computer, no  'Logging' Property can be found under DAQmx Read Property Node.
Question 2: I notice that when copying the main VI from one computer to another computer, some sub VI is not included and missing because the llb differencs on both computer. What to do with this problem?
Thank you.
Bing
(2,872 Views)
Hi Bing,
What versions of DAQmx are being used on both pc's? is it the same vi?
I would suggest bundling all the necessary vi's into a project...
Can you upload a screenshot of the error and the vi that is causing the issue?
Ashish Naik
Automotive Business Development Manager
National Instruments UK
(2,819 Views)
