DAQmx Start Trigger (Analog Edge).vi FAILS
"DAQmx Start Trigger (Analog Edge).vi" FAILS when running LabVIEW Example VI "Cont Acq Accel Samples-Int Clk-Analog Start.vi" with Error -200077 at Prop Node DAQmx Trigger (arg1) in DAQmx Start Trigger (Analog Edge).vi
Possible reason(s):
Measurements: Requested value is not a supported value for this property.
Property: Start.TrigType
You Have Requested: Analog Edge
You Can Select: None
Task Name: _unnamedTask<1>
Ty Williams
Systems Engineering and Project Manager
DCX-CHOL Enterprises, Inc.
12831 S. Figueroa St.
Los Angeles, CA 90061
310-516-1692 x126
tyw@dcxchol.com
(3,276 Views)
Seems your equipment doesn't support that function...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,274 Views)
You need to provide more information on the situation, e.g., what kind of device you are using, the setup, etc.
(3,270 Views)
Hi Ty,
Which card are you using?  You can go to www.ni.com and search for the board that you are using.  On the product page for that device, there's a specifications tab which will tell you what kind of triggering is available for your device.  If analog is not listed in there, then the error that you are seeing is expected.
Thank You,
Nick F.
(3,235 Views)
