DAQmx Timing Property Node missing 'more' options
Hello all
I'm using LabVIEW 8.2 and am trying to change the AI Convert Rate in the Timing Property Node to change the interchannel delay. (Using a 6008 and attempting to acquire 2 channels at the same time)
I don't seem to have the 'more' options available, but I can copy a timing node from another VI with the AIConv.Rate already set.
Maybe I missed an install option?
Thanks for any help!
Zach
(2,925 Views)
Hey zdub,
The AI Convert Clock can only be read on a USB-6008; it cannot be changed (more from this KB). This is likely why you aren't seeing the option to do so.
Ryan
Ryan P.
CLA
(2,874 Views)
Thanks Ryan!
I did run across that KB just a little bit ago. I guess I had a brain fart.
Thanks again,
Zach
(2,852 Views)
