DAQmx Virtual Channel Update Speed Is Too Slow
I'm trying to read DAQmx data directly over the Shared Engine Variable using the following code:
I'm finding that I can't get data faster than every 1 second, even though the Update Speed indicator is reading 0.00003 seconds.
I can't find anywhere that allows me to increase the speed at which the global virtual channel will be updated, I've already changed the ADC timing to high speed.
(3,028 Views)
That is more of the nature of the Shared Variable Engine.  Why are you using that anyways?  Just use the DAQmx API directly.  If necessary, use a separate loop that just reads the DAQmx channels and use a Queue or User Event to send the data to whoever needs it.
(3,004 Views)
