DAQmx assistant missing in Labview 2010 with DAQmx 9.22
I installed Labview 2010 followed by DAQmx 9.22 in Windows 7, 32bit. The DAQmx assistant is missing, I tried to copy DAQmx files from an working computer, it doesn't work. Previously I tested on Windows 7, 64 bit with the Labview 8 version, got the same problem. Any suggestions?
(2,763 Views)
I am having the same issue.
(2,735 Views)
I solved my problem.  I found I downloaded DAQmx 9.22 Config instead of DAQmx 9.22 itself.  The latter has more than 1G byte size, the former is smaller. Hopefully it would be useful for others.
(2,733 Views)
