DAQmx base ELVIS Bypass
Is there a way to switch the ELVIS workstation to bypass mode with DAQmxbase under linux?
I tried to modify the NI ELVIS enable Bypass vi, but I could not create a task that only uses half of the port0 lines.
Is there another way to switch the workstation to bypass mode?
Christian.
Message 1 of 1
(2,602 Views)
