DAQmx configure logging (TDMS) and time channel
I stream data directly to my computer via cDAQ-9172 with the help of block DAQmx configure logging (TDMS). Wonderfull, very good data speed. But I would like also have a time channel inside of TDMS file. But I wouldn't like to re-open measured file. Is it possible to save time channel together with measured channels? Thank you for reply.
(3,387 Views)
The timing information for the acquired channels is stored in the file and can be accessed simply by reading a waveform from the TDMS file (as opposed to an array of doubles).  Do you mean a time channel independent of the acquisition?
Andy McRorie
NI R&D
(3,369 Views)
Thank you for your quick reply. I would like to have channel with time information for each sample of acquired signal, see attached picture. I want to have same time channel which is always made by DIADEM DAC. Is it possible to do it by DAQmx configure logging (TDMS) block in Labview?
Thank you
Oldrich
(3,364 Views)
I will defer to the DIAdem experts on this (though I will let them know about your question).
From my knowledge DIAdem, you can go to the "Analysis" tab and find "Numeric Channels <-> Waveform Channels" under "Channel Functions".  Then, you can convert the waveform channel to two separate numeric channels of data and time.
Andy McRorie
NI R&D
(3,341 Views)
