DAQmx data acquisition
Hi, guys!
I am a freshman.
I have a trouble with DAQmx channel configuration.  I have two channel  to configure ,one  need  IEPE ,and another one  not , but in  the  example ,I have  to configure  both  of them to be IEPE stage or not .
And the  help  context tell me I have to use the  DAQmx  API to specify  the desired configuration .The question  is I don't  know  how to do it .
If you have any suggestion  or example, I would  be appreciate.
You can find the example with the guide  of the following picture .
Thx !
lease Mark the solution as accepted if your problem is solved and help author by clicking on Star kudoes.
(3,764 Views)
Duplicate thread: http://forums.ni.com/t5/LabVIEW/DAQmx-data-acquisition/m-p/3326805#U3326805
(3,745 Views)
I C.
(3,701 Views)
