DAQmx driver for LabVIEW Community edition
Based on the posted in the forum tried installing DAQmx 20 for my Community edition.
But the installation is not completing and getting struck in the below step and not progressing.
The windows security pop up keeps appearing even if i click on install.
Please help.
(2,459 Views)
I have tried the DAQmx  20.0 for community edition but getting struck in the below step
(2,450 Views)
You can check the "Always trust software from National Instruments" before clicking the Install button.
(2,448 Views)
It's not quite that simple.  It's supposed to be, but it's not.  I've had several occasions where, even if you select "Always trust..." the install will ask you over and over and over and over, making an unattended install impossible.
To the OP:
This is not an error, it's a warning.  You can click on "Always trust..." to keep the install gong, but, as mentioned above, you may have to keep doing this to keep it going.
Bill
CLD
(Mid-Level minion.)
(2,398 Views)
I have tried the selecting "Always trust" but its keep repeating the same step again and again
(2,345 Views)
Are you sure?  I had that pop up dozens of times before, even in the same module install.
Bill
CLD
(Mid-Level minion.)
(2,313 Views)
