DAQmx has no Advise VI, how can I get around that in my programming?
I am reading a switch through DAQmx, I need to make timing calculation on each change (on/off) but there is no Advise VI in the DAQmx functions. I need to use the on-change terminal on the Advise VI. I've implemented the same application using FieldPoint because it has the Advise VI, but cant figure out the programming when using DAQmx. I only get continous readings, but only want a reading on-change. Need to know how to get around this without using the Advise VI.
(2,775 Views)
The Advise VI that you mention basically gives you the option to choose between an event-driven acquisition or a poll-driven acquisition. There isn't an explicit VI that allows you to do this, its more of a collection of VIs that do this. Depending on what type of acquisition or generation you want to make (AI,AO,DIO, counter) I can tell you if it is possible to do this. So please, give me as much information you can about your system (PCI board, LabVIEW version, type of acquisition) and I should be able to help you out better.
thanks,
LA
(2,775 Views)
Thank you for the response, although after a couple of days thinking, I have figured out a solution. I am using AI (voltage), LabVIEW 7.1 and a PCI MIO-6036 board. I simply used a series of logic statements to obtain information at a certain event.
(2,775 Views)
I am glad you found a solution, using logic statements is a great way to use event-driven applacations. Please let me know if you have any additional questions.
LA
(2,775 Views)
