DAQmx is missing in LabView
I have just installed NI MAX 17.0.0 and LabView 2017 Professional Development System.
I have a USB-6008 DAQ board and have it installed (i.e. I see it in MAX, test it, can make a task etc.)
However in LabView any reference to DAQmx is missing - I cannot read a task for example. I have no idea what I am doing wrong and any help will be greatly appreciated.
(5,119 Views)
Accepted by topic author Kris_D
And you have installed NI DAQmx 17.1 with support for LabVIEW 2017 checked?
And you installed DAQmx after LabVIEW was installed?
(5,113 Views)
You need to install LabVIEW first.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288263
Thank you for using NI-DAQmx 17.0.0.  NI-DAQmx provides support for customers using NI Data Acquisition and Signal Conditioning Devices.
Install Application Development Environments, such as NI LabVIEW or Microsoft Visual Studio®, before installing NI-DAQmx. NI-DAQmx 17.0.0 supports the following NI Application Development Environment versions:
NI Application Software Versions Supported by NI-DAQmx 17.0.0
NI LabVIEW 2014, 2015, 2016 and 2017
LabWindowsâ„¢/CVIâ„¢ 2012, 2013, 2015 and 2017
NI Measurement Studio 2010, 2012, 2013, and 2015
NI SignalExpress
2014 and 2015
(5,113 Views)
Thanks a lot - I uninstalled an reinstalled in the right sequence (LabView first). Greatly appreciated!
(5,074 Views)
FYI, you did not have to uninstall.  You could have just installed DAQmx again.  All that would be installed would be the LabVIEW support, so it would have gone very fast.
(5,060 Views)
