DAQmx not in LabVIEW 2020
I have LabVIEW 2019 and DAQmx installed on my laptop and everything works fine, but when I install LabVIEW 2020 Community on the computer, DAQmx does not appear in LabVIEW 2020 Measurement I/O Palette, even after I reinstall DAQmx.
What shall I do to overcome this?
XL
(1,635 Views)
Make sure you install DAQmx 20.X.  DAQmx 19.X is not compatible with LabVIEW 2020.
(1,627 Views)
Crossrilz,
Yes, I do have DAQmx 2020.
In the mean time, I've found the solution. In the NI Package Manager,  I can select "Install and remove related package" option to add DAQmx to LabVIEW 2020.
Thanks.
XL
(1,612 Views)
