DAQmx offset
I have a task with two values.I start this task with the DAQmx read the values and get them out to a diagram.One of the values ia to high so i want to give it a offset.
How can I do this, how can I separate the signals after the DAQmx-vi read?
(3,332 Views)
You use the index array function to get the specific waveform you want add then you add or subtract a constant.
Message Edited by Dennis Knutson on 10-17-2005 11:17 AM
(3,325 Views)
Thank you Dennis Knutson, this helps me very much
(3,304 Views)
