DAQmx palette (versions 17.0/17.5) not showing in Labview 2017
I need to read some data from a cDAQ 9172 (compact series), which is compatible with DAQmx up to 17.5, which is then compatible with Labview 2017.
After following the intsructions and the correct order of installation (first Labview then DAQmx), I still can't see the DAQmx functions in the measurement palette.
I already tried to remove and reinstall DAQmx, but the issue persists.
Could you please help me to solve the issue? Is there anything else that I need to install?
Message 1 of 1
(867 Views)
