DAQmx property node attributes
I've just acquired the DAQmx US-6009. I was wondering where I can find a list with the descriptions and types of all the properties that are accesible through a property node, of the different objects of the DAQmx palette (ex: DAQmx Channel).
Thanks!
(2,738 Views)
Hi marc,
use the context help!
- place a DAQmx property node, select a porperty
- open the context help for that property
- now click the link to "properties for class DAQmx..."
(2,731 Views)
Hi, marccj,
here you are a tutorial which contains a couple of documents than you can read instead of starting with property nodes from scratch:
http://zone.ni.com/devzone/cda/tut/p/id/5470
and, for instance:
http://zone.ni.com/devzone/cda/tut/p/id/5379
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH72CAG&l=en-US
On the other hand, there are lots of properties associated with this nodes. The best practice to understand their particular behavior is using the context and detailed help in LabVIEW.
Espero que esto te ayude. Saludos!
Jesús.
(2,705 Views)
