DAQmx read: file not found during build, but existing on disk
While bulding the applicationLabView states that it can't copy "DAQmx Read.vi" because the source file does not exist. The file mentioned does contain the vi, I can open and view it, LabView has no problems with the vi, I can even run my program using the vi in the development system.
(3,038 Views)
Hello kai_n,
are you logged in with administration rights?
What LabVIEW version do you use?
Are you using the DAQmx or the DAQmx base drivers and which verisons?
Have you tried to reinstalled, or to repair the DAQmx driver?
I have make an picture where the DAQmx read.llb is placed on
your computer. You shoud have the same file on your PC, if not
the DAQmx installation is corrupt.
best regards ALEX
best regards
Alexander
(3,012 Views)
