DAQmx read progress
I am collecting 5000 samples per channel on 16 channels using the DAQmx VI's.  I would like to have a progress bar that is updated as the data collection takes place.  I have attempted to use the "Current Read Position" property node, however it only outputs the total number of samples taken once the task is complete rather that constantly updating.  Thanks.
(3,284 Views)
I don't think you can exactly do what you are trying to do.  As I think you've discovered, the DAQmx read VI is holding until the given amount of sample are read.
A possible work around if you know the number of samples to read and the sample rate is to generate the progress bar in a parallel loop.  Have that loop begin when the DAQ mx read begins.  Let's say you are doing 5000 samples as 50 samples /second., then you know it would take 100 seconds to read.  Use timing functions in the parallel loop to update the progress bar as a percentage of time that has passed.  If your timing is correct, the DAQmx read and the parallel loop should end at about the same time.
(3,282 Views)
Thanks for the help.  Using your suggestion, here is what I came up with and it seems to work. The TRUE case just has a value of zero written to a property node of "Progress".
(3,275 Views)
Try using the DAQmx Read property Available Samples per Channel.  This will give you the right numbers.  Attached is an example (in LV8.5).  I will also attach a pdf with the block diagram in case you do not have 8.5.
Message Edited by rpursley8 on 01-09-2008 08:00 AM
Randall Pursley
(3,253 Views)
