DAQmx simulation not happening in MAX 4.5. any configuration manipulation needs to be done.?
I'm not able to simulate DAQmx on MAX 4.5.1 on right clicking the Devices and interfaces in MAX it shows create new but DAQmx does not show up. The installed DAQmx driver is 8.6.1. Is it that anything needs to be changed in the administrative tools?
please suggest.
Rakesh
(3,382 Views)
Rakesh,
DAQmx is a driver that handles hardware. Are you trying to simulate a particular DAQmx device?  From the options you want to choose Simulated NI-DAQmx Device or Modular Instrument, then select which device you want to simulate. Here's a great walk-through:
NI-DAQmx Simulated Devices
Cheers,
Misha
(3,367 Views)
Hi Misha,
Well in the list there is no such option as simulated DAQm.
(3,352 Views)
It doesn't look like you have DAQmx installed.
If you did, MAX would look more like this:
Message Edited by Ravens Fan on 04-16-2010 12:19 AM
(3,350 Views)
Well DAQmx 8.6.1 is installed
please see the highlighted area in the attachment.
(3,342 Views)
Hmm... I would try repairing the driver from Add/Remove programs > National Instruments Software > NI-DAQmx > Repair, and if that does not work, install a newer version of DAQmx - I see you have Labview 8.6, but DAQmx 8.6.1 only supports up to Labview 8.5, so you'd probably want a newer driver anyway.
Misha
(3,323 Views)
The problem got resolved. I reinstalled the driver and now it works fine.
Rakesh
(3,313 Views)
