DAQmx task as a Project shared variable
What data type do I use when defining a shared variable for a DAQmx task name?
I have tried String, but when I use the shared variable that I call 'Digital IO Task' in a subVI, I get the following:
Error -200088 occurred at Main Panel.vi
Possible reason(s):
Task specified is invalid or does not exist.
(3,756 Views)
Hi GretchenSkelly,
I believe that you can configure shared variables with NI-DAQmx global channels and NI-DAQmx local channels as stated in this article, but we cannot bind them to NI-DAQmx tasks. I tried with both variant and string data types and it kept showing an error. However I tested with strings with the code below and it seemed to work. I was able to see the value in the shared variable with a shared variable read node and in the Distributed System Manager (DSM). Are you able to see the shared variable update in the DSM?
(3,723 Views)
Amezam,
there reall is no need to gyrate a DAQmx Task IO through a flattened string.  Scan to string pulls "DAQmx Task.Name" just fine if the coersion dot offends your style guidelines.
(3,717 Views)
Thanks for both replies.  I ended up using Global Variables.  I hadn't used globals for years.
But that seems to have solved my problem of passing DAQmx Task Names to subVIs.
Gretchen
(3,699 Views)
