DAQmx tdms logging and wf_start_time
Well that's a bummer... Are you using a RT system?
Message 11 of 14
(1,212 Views)
No RT target to deploy to however, the vi lives fine in a RT target and runs via the context switcher no trouble.
How does my Code Capture compare to your code? what happens if you run it on your RT Target
Message 12 of 14
(1,208 Views)
I have only been running this on my RT target.  The way I am reading the property is identical.  THe way I am storing the TDMS file though, I haven't seen how you are doing that yet.  My VI is really complex at the moment since I'm experimenting with complex triggering.  I'll see if I can get it to replicate in a simpler VI.
Message 13 of 14
(1,205 Views)
A simple DAQmx configure logging mode read and log on a two channel AI task (simulated M series device.)
Message 14 of 14
(1,202 Views)
