DAQmx timinig
Im working on litte program, with aquisition data from LAMP. Program is specified for (max) 3 lamps. When I start one lamp of three, then timinig is approximately <1,26;1,52> seconds. But a starting tests all of these three lamps delayed time is up approximately <4,2;5> second. I thing is not good. Better is <1,5;2,5> seconds.
I use NI cDAQ-9178, NI9225 (Voltage modul), NI9227(Current modul) and 4x NI9211(temperature modul).
One testing lamp I use one port of NI9225, one port of NI9227 and four ports of 9221. Each test of lamp is independent on timing.
Tell me please, where I make mistakes when time is too much delaynig. Im beginner but I stil learning 🙂
Thanks Norbert
(2,664 Views)
Good Afternoon Norbert,
I am curious to where you are seeing your delay.  Are you seeing it between some indicators on your front panel or between the actual points you are acquiring in the text file you are generating after the run of each case?
I hope you have a great rest of the day!
-Cody C
(2,630 Views)
Hellou Cody C,
Delay is between lamps, but I reached new solution when is delay aprox. 1,6second :). I dont understand what doing "Stacked sequence structure" I thing  to use a paralel aquisitio but is serial :).
Thanks to read but I find solution.
Norbert
(2,613 Views)
