05-21-2009 09:26 AM - edited 05-21-2009 09:29 AM
Hi!
I'm new with Labview.
I have intaled Labview 8.6 (evaluation edition) and i'm trying to do a program to aquire data from a NI 6008.
However at start i have instaled Ni-DAQmx 8.6 from CD but in Functions Panel it doesn't appear the DAQ Assistant Express VI.
Then i have daownload Ni-DAQmx 8.7 but when I try to install it doesn't appear the Labview 8.6 support.
Do I have to download Ni-DAQmx 8.9?
Then i need to do a program to aquire data from a Ni 6008 to determine the flowrate that passes over a flowmeter.
I'm reading the "getting started" from Labview and http://attila.sdsu.edu/me295/modules/labview/intro/introduce.html
However the flowrate vary the frequence response of the inductive flowmeter (http://arquimedes.net/sens/sensor_de_caudal.htm)
Do I will aquire the voltage or the frequency?
But to start I need to know how the hell do I get the Ni-DAQm support for Labview 8.6 (evaluation) to get the DAQ Assistant Express Vi as shown in getting started (page 4-2).
I have the MAX version 4.5.0f0 where I can see the NI 6008 board.
Carlos
05-22-2009 03:35 AM
05-22-2009 04:51 AM
The flow rate is proportional with the frequency coming from your flow meter. You may use the onboard counter on the 6008 to find this frequency. You will find some ideas here http://zone.ni.com/devzone/cda/tut/p/id/7111
05-22-2009 10:38 AM
But my signal is an analog voltage.
The PFI0 port on NI 6008 only counts digital signals, I think.
05-22-2009 11:17 AM
oort wrote:But my signal is an analog voltage.
I do not speak Spanish. But it look like your flow meter have a output equal to VCC-0.4. So if you apply 5 volt as VCC you should be able to use the counter.
05-22-2009 11:45 AM
It's portuguese.
I think that the more important informations are:
Flowrate : 0,025 - 2,5 l/min
Voltage output: 0.1 to 3V (aprox. sinusoidal).
05-22-2009 12:33 PM
Sorry my Portuguese is not strong either![]()
from the data sheet on 6008 I can see that the minimum input high voltage is 2 volt. If your signal is fluctuating between 0.1 and 3 you should be able to use the counter. It does not matter if it sinus like because the digital logic only know two states, on or off
05-22-2009 01:28 PM
Well, using "Tone Measurements" after DAQ I get a "frequency".
I don't know if it gives the same value as if I used a counter but on monday I will try to do a calibration with this frequency.
With the valve almost closed I get 3-4 Hz and then start rising until 90Hz with the valve fully opened.
I hope it give reasonable results. 🙂
Thanks.
