DAQmx write problem
I've designed a VI to send a ramp signal to a DA-converter but having difficulties executing it. The VI was designed and tested succesfully on a different system, but attempting to run it on my new system it does not work. The program simply won't finish. Using the highlight execution tool I see that the execution does not proceed from the "DAQmx write" box. Certainly this must be a problem related to settings or the software installed on my computer, but what might be missing? My system runs LabVIEW 2011 on Windows 7. I'd be very grateful if anyone out there could provide me with a helping hand.
(2,372 Views)
The vi will wait for 10 seconds and through an error if it is having an invalid task. Check the device name specified in the physical channel in the code and the MAX. Apart from that I don't see any problem with your code and it ran fine in my PC.
(2,369 Views)
