DAbort 0x1A7102DF in fpsane.cpp when opening a 2011 vi in a machine with 2012 vs
Error message appears when i try to open a vi with LV2012 created in other computer with 2011 version.
Does anyone know how to fix it?.
(3,587 Views)
Does the VI open correctly on the 2011 machine?
Do new VIs work correctly on LV 2012? What about opening shipped examples?
Norbert
Norbert
Expert: Geometry
(3,585 Views)
Hi serviciencia,
it sounds as if your VI was corrupt. It is perfectly possible to open a LV2011 coded VI with LabVIEW 2012. If you cannot open this VI with 2011 versión, your VI is clearly corrupt and you'll have to rewrite it. Make backup copies to avoid this annoying situation. If you are able to open it with LV2011, try to repair this version of LabVIEW, it may be badly installed.
I hope this helps!
Jesús
(3,529 Views)
