DB Tool insert data- Time stamps not saving in sequence
Hello all i am using DB Tool insert data to save the parameters every one minute that i receive to the pc. With respect to time stamp and value
Firstly i save them in TDMS file and after 300 Records i push all the 300 records into DB file
Every thing is ok but some time the time stamps( taken from pc ) in the file are not saved in a sequence manner . This is happening rarely
if i debug also i could not found the problem .
Can any body guess what could be the  problem
Thank you..
Message 1 of 1
(2,780 Views)
