DB Tools List Tables.vi issue
Hello Everyone,
I am using the DB Connectivity Tools in order to read/write data from/to a MySQL database located on an Unix machine.
Connecting to and exchanging data with the database work but when I try to list the tables in the dB using the DB Tools List Tables.vi I get an empty array.
Has anyone encountered this error before, is there a solution for it?
Florin
(2,799 Views)
Hello florinn
Yes, that is a known issue. I have reported this bug to Ni some time ago, and the new version of DB toolbox has corrected this problem.
The whole discussion you can find at the thread called: "DB Toolbox List tables - does not work properly".
Hope it helps.
regards
Pawel
(2,799 Views)
