DB tool kit, multiple computers opening and closing connections
Silly question, but I'm paranoid and unable to test this while working from home. Multiple computers running the same program. Is there going to be an issue/race condition problems with the DB open connections and close connections running at the same time?
(2,577 Views)
BTW using Microsoft SQL for the database.
(2,554 Views)
A "good" data base will handle that for you. You will want to have good error handling in your program.
Former Certified LabVIEW Developer (CLD)
(2,535 Views)
Accepted by topic author breezy45
This is generally only an issue with a file based database like MS Access or SQLite.  I haven't actually done this, so I can't comment directly, but theoretically server-based databases like MS SQL should handle concurrent connections with no problem.
(2,524 Views)
By the way, DB tools kit,is only for sql server ?
For mysql, which tools we should use ?
Thanks.
Keep moving
(2,383 Views)
