DBL cluster to Build Array and to xy-chart
HI Friends,
I  have a doubt in connecting a Double Floating point  type cluster to a Build Array....
In my program vi ...I plotting the data on the chart as well as on the graph...
I have a little problem in showing these data on the chart...
I can able to plot these data in a separate chart individually.....
But i required to plot it x-yy manner...
one data is x-axis and other two data are in y-axis...(length in x-axis and speed in y-axis)..
I attached my vi in this mail for ur suggestion...
regards
rajasekar
(3,028 Views)
Hi Raja,
you cannot plot xy-data in a chart - you have to use a xy-graph! See the online help for graphs (or look for some examples) on how to connect the x- and y-data properly.
Personal opinion/comment: Instead of using this big mathscript node you should use standard LabView functions, especially for this rather simple if/then/else construct.
Message Edited by GerdW on 04-24-2007 01:05 PM
(3,023 Views)
Hi GredW,
Thanks for ur reply,....
I did with XY graph...... as u suggested....
As per with Mathscript suggestion ,..this is sample  appliaction...later on application become complex..
that's why i used simpler method...
Regards
rajasekar
(3,016 Views)
