DBL to digital conversion
Hii
I am trying to convert DBL(voltage) to Digital (16 Bit).
can someone please help me with that??
Message 1 of 9
(4,614 Views)
You have to define rules before being able to do so.
Digital patterns are easily converted to integer numbers ('binary pattern'), but floating point numbers (like a DBL) have a decimal sign and post-decimal numbers. What about those?
Norbert
Expert: Geometry
Message 2 of 9
(4,602 Views)
as norbert said, you should be more specific in what you want to accomplish,
especially if you'd like ppl helping you out, otherwise you will get answers like this:
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 3 of 9
(4,555 Views)
Accepted by topic author Chirag_Vekariya
DBL to digital.png/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 9
(4,547 Views)
@yamaeda reverse code golfing? ... i liked the red coercion point
Message 5 of 9
(4,532 Views)
@jwscs wrote:
@Yamaeda reverse code golfing? ... i liked the red coercion point
Smiley Tongue
I can offer a couple of thoughts...
The implicit conversion posted by yamaeda shows how to do the conversion in a block diagram. You r version would require using your code as a sub-VI.
On the other hand...
At one time I discovered in one version of LV the implied coercion was actually faster than the implicit.
Choose your poison,
Ben
Message 6 of 9
(4,524 Views)
@ben .. i suppose you mean explicit (yamaeda's code)
but why would mine need to be a subvi?
regarding speed/memory i read some post from altenbach, where the implicit coercion was faster, bc it didn't need to create a new buffer (or somesuch).
regards
Message 7 of 9
(4,516 Views)
@jwscs wrote:
@Ben .. i suppose you mean explicit (yamaeda's code)
regards
That is correct. Yours would have to be made into a sub-VI because the only numeric wire on your diagram was still a float. It was only when it was put in the indicators did it become a I32.
Ben
Message 8 of 9
(4,513 Views)
that is totally right, i didn't look at it that way 😉
Message 9 of 9
(4,509 Views)
